Most likely this was caused by an error in SSRS. For other people who ever see this, whether in 2019 or newer, try running some reports from the DPM Console. Most likely those arent working properly because of a DLL needing to be replaced. Once SSRS is working properly, the job list should get and stay populated.
DPM 2022 not show running jobs and finished jobs
Mike 12-2
6
Reputation points
I have mounted a DPM 2022 server with SQL 2019 on a windows server 1016.
The problem is that if I launch the inventory, or another job, it visually disappears even though it is running. It seems as if the jobs are not saved in the history or something like that.
Any idea where the problem could come from?
Thanks.
