How to fix no sound or low sound error on Windows 11
amthanhtrungchinhaudio 15 Reputation points
2024-01-11T03:54:44.2333333+00:00
Hello When I updated to Windows 11, the sound on my computer became much quieter. I have tried many ways but have not been able to fix this problem. Looking forward to receiving your help.
Windows for business | Windows Client for IT Pros | User experience | Other
    2024-01-17T03:12:01.8+00:00
    Hi amthanhtrungchinhaudio,
    Please first run the Audio Troubleshooter. Open Settings, go to System - Troubleshoot - Other troubleshooters, click the Run button next to Audio, then follow the on-screen instructions to complete the troubleshooting process.
    If the troubleshooter does not help, try updating the audio driver. Run devmgmt.msc to open Device Manager, go to "Sound, video, and game controllers" section, right click your audio device and select Update Driver. If Windows cannot find available driver to update, check the latest driver on the audio adapter or motherboard manufacturer site.
    Best Regards,
    Ian Xue
    If the Answer is helpful, please click "Accept Answer" and upvote it.
  2. Kapil Arya 35,136 Reputation points Volunteer Moderator
    2024-01-11T08:10:14.5166667+00:00
    See if this fix helps you:
    https://www.kapilarya.com/fix-sound-not-working-on-windows-11
    Let us know if this helps!
    Note: Included link in this reply refers to blog by a trusted Microsoft MVP.
    *This reply was updated to make sure it is valid.
