Changing Overlay power Mode with script
Mustaffa Abu-Sedira 0 Reputation points
2025-02-02T09:38:46.71+00:00
I want to change the overlay power mode based on time of the day without having to go to settings -> system -> power and battery -> power mode each time.
I am not able to find which command in powercfg will change the OVERLAY power mode, all the commands seem to be applicable only to the control panel power scheme settings.
I am looking for a command that I can run from cmd or powershell to set the power mode: Balanced, Best Performance, or Best Power Efficiency and then call it from a scheduled task.
Can anyone help with this?
Thanks
Windows for business | Windows Server | User experience | PowerShell
  1. guilherme rodrigues 390 Reputation points
    2025-02-12T15:30:34.4733333+00:00
    Hi, @Mustaffa Abu-Sedira !
    Windows stores the overlay power mode setting in the registry under:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\User\PowerSchemes
    The available Overlay Power Modes correspond to these registry values:
    Power Mode Registry Value
    Best Power Efficiency 1
    Balanced 2
    Best Performance 3
    You can Run PowerShell as Administrator and use one of the command:
    Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Control\Power\User\PowerSchemes" -Name "ActiveOverlayAcPowerScheme" -Value 1
    After setting the registry value, apply the new setting by running:
    powercfg -update
    You can schedule these commands to run at specific times of the day using Task Scheduler.
