Using the usb-c cable to listen to audio between my Surface Duo (gen 1) and Surface Headphones (gen 1)
2021-10-14T19:17:34+00:00
Previous Locked thread, so reposting
https://answers.microsoft.com/en-us/surface/forum/all/usb-connect-surface-headphones-to-surface-duo-for/e82a3366-a710-437f-bc3a-d2c6eda03c2c
I am in an environment where I can not have wireless devices. I recently got a Surface Duo (gen 1) and I already had the Surface Headphones (gen 1).
I connected my Headphones to my Duo with a USB type C. When I started playing my audiobook, I could not get the music to play through the USB port. What can I do to enable this feature.
Surface | Surface Duo | USB-C
    2021-10-14T19:27:51+00:00
    Good afternoon Gauntlet_KI,
    The Surface Headphones do not have a function that allow incoming audio through the USB-C port. We recommend that you use a USB-C to 3.5mm adaptor HERE to connect using a audio jack to the Surface Duo.
    2022-01-03T15:48:15+00:00
    That is just crazy that I have to use an adapter to an older technology connector to do this. It is like going from a HDMI and having to convert it down to VGA to obtain audio.
