Mine give an echo...and where is the MUTE BUTTON?
TEAMS certified devices (these Surface Earbuds) do NOT have a mute button for calls. Although Earbuds are nice for mobility, you'll need to carry around your laptop if you need the mute button during a meeting. Think working from home with children, dogs, spouse, cat, parents, lawn mower, making coffee for a few examples.
And then there is the volume across Microsoft Services and Devices in general. For example, lets say you have a Surface Laptop, Surface Earbuds and are using TEAMS for a conference call...it is as if three companies are trying to take over the OS. Why must I figure out HOW to control volume depending upon what I am using for the meeting?
Also, the earbuds seem to reset at each call to HIGH volume - which is painful.
The Surface Headset is also challenging. For examples, I cannot use if the microwave is running or near a portable AC without a sound similar to a fire-alarm blaring into my ears. Super painful! Is that because of the same frequency?
And why so many volume options that do NOT work? For TEAMS I find I need to go to Control Panel, Settings, Sound, Scroll down past Master Volume to ADVANCED SOUND and fix volume for the specific TEAMS call. I've not been able to use Master Volume, Volume controls on your desktop toolbar, or Sound Settings. They don't seem to work.
When you add the Earbuds - it can be more tricky and swipe does not work well with TEAMS...it does with music.
Then there are general maintenance/updates that need to be installed outside of the "Check for Updates" for the OS. For Surface Headset and Earbuds, install the Surface Audio App to get updates.
