Surface Pro 4 Battery not recognized
2022-06-06T19:19:30+00:00
I have replaced the original battery DYNR01 of my SP4 with G3HTA027H. But the new battery is not been recognized by surface and switched on only when connected to the mains.
On the logon screen it shows the battery symbol with X on it on the bottom right corner.
No battery symbol on the system tray.
No info on battery on the power settings screen.
No ACPI driver details under battery in the device manager.
Just wanted to know is this due to the fact that I replaced worth another type or something else is the cause.
I even updated the windows and firmware etc. But the issue is still there.
Any support in resolving this issue is much appreciated.
Surface | Surface Pro | Power and battery
    2022-06-07T17:24:23+00:00
    Hi vjayapau,
    Thank you for reaching Microsoft Community.
    As much as we would love to assist you on this but I'm sorry Microsoft does not not support devices that are tampered including modifications of internal components. See: Warranty and Protection Plan Terms & Conditions (microsoft.com) and Microsoft Services Agreement for details.
    Kind regards,
    Marrion
