If you've issue with sound on the system, refer some relevant suggestions here in this community guide:
troubleshoot of sound output and input
troubleleshoot of sounds in output and input of the computer
Windows for home | Windows 11 | Input and language
2025-06-21T17:27:10+00:00 Hi Om,
You've found your tech home, thanks for posting in the Microsoft community!
To troubleshoot sound issues in both output and input on your computer running Windows 11, you can follow these steps:
- Check the volume: Ensure that the volume is turned up and not muted on your computer.
- Check audio connections: Make sure that your speakers or headphones are properly connected to the correct audio port on your computer.
- Update audio drivers: Go to Device Manager, locate the audio device, right-click on it, and select "Update driver." You can also visit the manufacturer's website to download and install the latest audio drivers.
- Run the Windows Audio Troubleshooter: Go to Settings > System > Sound > Troubleshoot to run the built-in audio troubleshooter.
- Check default audio device: Right-click on the speaker icon in the taskbar, select "Open Sound settings," and ensure that the correct audio output device is selected.
- Check microphone settings: If you are facing input issues, ensure that the correct microphone is selected as the default recording device in the Sound settings.
- Restart Windows Audio service: Press Win + R, type "services.msc," locate Windows Audio service, right-click on it, and select "Restart."
If these steps do not resolve the issue, please provide more details about the problem you are experiencing for further assistance.
Thank you for your understanding and cooperation.
We wish you a good day!
carole | Microsoft community Moderator
ReportedAnonymous
2025-06-25T20:05:27+00:00 I tried all the steps but still no sound
