Edge 139.x vs Edge 138.x : IE mode do not display correctly pdf
KENDZIORA Arnaud 0 Reputation points
2025-07-22T13:10:32.8733333+00:00
with Edge 138 : the pdf file is displayed correctlyUser's image
with Edge 139 (Beta) : the pdf file is not displayed correctly
but we can see acrobat menu (with right clic).
(by using "print", we can get the file correcty)
Microsoft Edge | Read PDFs | Windows 11
  1. Time Lady 37,510 Reputation points Independent Advisor
    2025-07-22T14:05:33.97+00:00
    Hello, I’m Virginia a fellow windows user.
    Sorry to hear you’re experiencing problems.
    As you’re using a Beta version then it’s most likely a bug, please report it via Windows key + F key. In the meantime if reading .pdfs is important to you then either roll back Edge to the previous version (if possible), use another program/app to read the files until the problem is fixed or await a fix.
