power point is stuck on draw menu
Raleigh Estrada 0 Reputation points
2025-07-26T18:33:38.19+00:00
My Powerpoint is stuck on the Draw menu. nothing I do allow me to change to a different menu. When I select Home it briefly <1 sec changes to Home meu but immediate reverts back to the Draw menu. This is also true of Excel and Word apps. Seems like a software bug. How can I fix it?
Microsoft 365 and Office | PowerPoint | For home | Windows
  1. Kimberly Olaño 7,580 Reputation points Independent Advisor
    2025-07-26T20:39:48.71+00:00
    Hi Raleigh, this is Kimberly, an independent advisor, I'm glad to assist you today.
    In any Office app (PowerPoint, Word, Excel):
    Go to File → Options → Advanced
    Scroll to Pen settings
    Uncheck: Use pen to select and interact with content by default
    Save and restart the app.
    or temporarily disable touch or pen in Windows
    Turn off the tablet or touch device, or temporarily disable touch input:
    Open Settings → Devices → Pen & Windows Ink
    Toggle off options like Ignore touch input when using pen
    Or disable touch display/peripherals, then relaunch Office.
    Should you have questions, please let me know.
    Kimberly
