How do i get Collections to work on Edge for Android?
Penrose Albright 25 Reputation points
2025-08-05T02:20:05.52+00:00
Links saved to Collections in Edge for Android just don't work and haven't for months. Any thoughts on when this might get fixed?
Microsoft Edge | Other | Android
  1. Jeronimo Fuerte 16,785 Reputation points Independent Advisor
    2025-08-05T02:58:58.5733333+00:00
    Hi there! Unfortunately, collections won’t open in Edge Android version 137 and 138.
    You could install Edge Beta/Dev (version 139.0.3405.xx or newer). Links should open normally again.
    For a fix that doesn’t include changing to the Beta version, Edge Stable version 139 is scheduled to start rolling out the week of August 7, 2025. Once it’s available, Collections should work again without any issues.
  1. Gerold B 5 Reputation points
    2025-08-07T08:01:53.9033333+00:00
    I'm on 138 and also having issues with collections. In my case collections will open but I cannot add websites. All my 3 Android devices have the same issue so I'm assuming that this is a bug in Edge.
    Ive tried:
    Disabling all content blockers (adblock etc.)
    Setting DNS to default
    Cleaning cookies/cache
    Re-syncing
    Re-installing
    It's one problem after the other with Microsoft. Record profits but at the cost of thousands of employees fired. One wonders if there is a connection to all these little nagging issues that keep popping up in MS products...
