AUTO ROTATE NOT WORKING ON MY SURFACE PRO 7+
oussama errafik 0 Reputation points
2025-08-05T12:02:56.23+00:00
hi everyone i am currently having an issue with my microsoft surface pro 7+ i lost the feature to auto-rotate i did everything installed the lastest firmware and windows update, this all happened after i updated windows and my intel gpu drivers and i did roll back the update for the graphics driver but still rotate i tried reinstalling the intel sensor collection and the problem still persisted i am hoping it's not hardware related issue
Surface | Surface Pro | Display and screen
  1. JANSHER 855 Reputation points Independent Advisor
    2025-08-05T13:24:39.07+00:00
    Hi oussama,
    Welcome to Microsoft Community, Thank you for reaching us. We apologize you are getting this problem on your Surface Pro 7 Plus. Possible reason it might affect the roll back of the driver or updating the recent driver.
    But don't worry rest assure we will give our best to help you with this problem.
    Please follow this technical steps to fix the issue:
    SURFACE DIAGNOSTIC TOOLKIT (CHECK DIAGNOSTIC)
    If you don't have SURFACE DIAGNOSTIC TOOL KIT yet
    please download this in Microsoft Website.
    Open any browser
    Ggo to "https://apps.microsoft.com/detail/9nf1mr6c60zf?hl=en-us&gl=US"
    Download and install the "Surface Diagnostic Toolkit"
    Once install launch Surface Diagnostic Toolkit app
    Run full scan (It will automatically start scanning your Surface pro for Hardware and Software driver issue.
    Once update is completed restart your Surface 7 Pro Plus
    Check if Auto rotate is working
    If still did not help follow next step
    CHECK STATUS IN UEFI
    restart your Surface 7 Pro Plus and press Volume Up + Power to enter UEFI.
    Once your inside UEFI mode check for the "Device Configuration, Sensors.
    Save and Exit
    If there’s anything more you’d like to share or questions, please don’t hesitate to reach out.
    Warm regards,
    Jansher Liwag
    Microsoft Community
  2. oussama errafik 0 Reputation points
    2025-08-05T13:54:15.7333333+00:00
    hi i run the test and the diognosis app wasn't able to dectect the sensor Screenshot 2025-08-05 143924 also the sensor tab in my uefi is missing DSC_0864
    he's some information about my hardware and firmware versions you might find usefulDSC_0865
  3. JANSHER 855 Reputation points Independent Advisor
    2025-08-07T14:27:30.7433333+00:00
    Hi oussama,
    Thank you for responding. Possible that Sensor may be malfunctioning you need to reach out to Microsoft Support for Surface. Please follow this steps below.
    Open any browsers
    Go to https://admin.microsoft.com/ /support/microsoftsurfacesupport
    Log in using your Microsoft Account
    On the left pane Menu tap or maximize "Support"
    Tap on "Microsoft Surface Support"
    Create Service Request
    Provide all the information you get from your Surface Pro SN#, Model, Issues.
    Enter your contact details
    Choose for Call, Chat, Email support.
    Review before submitting the request.
    Warm regards,
    Jansher Liwag
    Microsoft Community
