Dear Ryan Priest
Welcome to Microsoft Q&A
I am sorry for what you have met, and I am understand that your login problem on your new iPhone brought an inconvenience for you.
In this situation, you could consider trying some troubleshooting below:
- If you previously enabled backup on your old iPhone or iPad, you could restore your Authenticator accounts on your new iPhone:
- Open the Microsoft Authenticator app on your new iPhone
- Tap “Restore from backup” at the bottom of the screen
- Sign in with the same Microsoft account used on your old device
- Your saved accounts (including 2FA codes) should reappear
For your reference: Restore account credentials from Microsoft Authenticator - Microsoft Support
- If backup wasn’t enabled, you’ll need to manually recover access to your Microsoft account:
- Go to the Microsoft Account Recovery Form
- Enter your personal email (Gmail) and follow the prompts
- Provide as much detail as possible—past passwords, Xbox Gamertag, services used, etc.
Help page: I lost my two-factor authentication program and can't access my account now - Microsoft Q&A
If you still cannot access your account through the above method, I would suggest you contact our online agent to check the account status for you.
Please use an available personal Microsoft account to contact an online agent:
- Click on this page Contact Us - Microsoft Support, type "Account & Billing" to search and click "Sign in to contact support" at the bottom of the page.
- Sign in to another available Microsoft account. Make sure you log in with your personal account.
- Under Products and Services, select "Other Products".
- Under Categories, select "Manage Account Security" and click Confirm.
- Click on "Chat with a support agent in your web browser".
Moreover, if you still have access on your iPad, try going to https://account.microsoft.com/account?refd=copilot.microsoft.com&ru=https%3A%2F%2Faccount.microsoft.com%2F%3Frefd%3Dcopilot.microsoft.com&destrt=home.landing&pageName=Accountand:
- Turn off two-step verification (if possible)
- Add a new trusted device or phone number
- Update your security info to help with future recovery
Hope it will help. Kindly update for me if you need further assistance.
