Hello Izz,
Thanks for reaching out to the Microsoft Community. I see that the battery icon is not showing on Windows 11 taskbar. It could mean that Windows is not detecting the battery properly. May I know when was the last time that the battery icon showed up? For the meantime, here's what you can do.
- Open Device Manager by right clicking the Windows icon > choose device manager > then expand the batteries section. You should see: Microsoft AC Adapter and/or Microsoft ACPI-Compliant Control Method Battery. If they are missing, it's a possbile driver or hardware problem.
- Enable the battery icon in taskbar settings. Search settings on the search tab > personalization > taskbar > other system tray icons and make sure the power toggle is turned on.
- Run the Surface Diagnostic Toolkit app to check for hardware and driver issues.
- Run a Windows Update and check if there is surface firmware udpates via the surfcae app or windows update page.
I hope this information is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer or needed more help, please click "Comment".
All the best,
Restee | Microsoft Community Support
