Surface Pro7 Battery replacement in South Africa
Kamogelo Molawa 0 Reputation points
2025-08-08T05:15:51.7033333+00:00
Hi There,
My battery in no longer charging fully. I've checked my battery settings however, it seems to me that the battery might have reached its end of life.
Kindly assist with recommending a service provider accredited with Microsoft that I can go to in order to get my tablet repaired please.
Also, how much will it cost me to replace my battery?
Regards
Kamo
Surface | Surface Pro | Power and battery
  1. Jeric 1,685 Reputation points Independent Advisor
    2025-08-08T16:47:39.2+00:00
    Hi Kamo,
    Thanks for reaching out. If your device isn’t covered by Microsoft’s warranty or a protection plan anymore, you can still get it serviced for a fee.
    You can check out all the details and choose South Africa from the dropdown on this official page Microsoft Out-of-Warranty Service Cost
    Hope that helps!
    Best,
    Jeric.
