How to fix problem with Chrome and visual studio..navegater not loading
Hopeemr 0 Reputation points
2025-08-13T17:31:36.6966667+00:00
The navigator isn't displaying using various browsers, including chrome. Microsoft Edge does display it. We thought it might be a security issue so added our url to secure sites. Also deleted extensions and cleared cashe and cookies. Any other suggestions?
Developer technologies | Visual Studio | Other
  1. Gyanendra Singh 0 Reputation points
    2025-08-14T05:17:40.2233333+00:00
    Hi @Hopeemr
    The very first thing, you can try to find the all installed browsers in the list, as shown below.User's image
    Now, if you can't find any of the browser except Edge, the likely causes are:
    • The wrong runtime is being picked up for “Chrome” or “Custom” browsers.
    • A Visual Studio browser cache/profile corruption.
    • A network security policy blocking the embedded control’s requests.
    You can then try following steps:
    1️⃣ Reset Visual Studio’s browser configuration
    Close Visual Studio.
    In your project’s root folder, delete the .vs folder (this wipes cached settings including browser profiles).
    Reopen Visual Studio and re-select the browser from the dropdown.
    2️⃣ Change Visual Studio’s internal browser engine
    ToolsOptionsWeb Browser and Preview.
    Under Web Browser, choose Edge (Chromium) — even for Chrome testing, it’s more reliable inside VS.
    If you must test in Chrome, use the external browser option (right-click the file → “View in Browser” → Chrome).
    3️⃣ Check Internet Explorer mode security
    Since VS’s internal viewer still relies partly on old IE engine for non-Edge settings:
    • Open Internet Options (Win + R → inetcpl.cpl).
    • Go to Security tab → select “Trusted sites” → click Sites → confirm your URL is listed.
    • On the Advanced tab, make sure:
      • “Enable Enhanced Protected Mode” is unchecked.
      • “Use software rendering instead of GPU rendering” is checked (test both ways if needed). Steps to Try 1️⃣ Reset Visual Studio’s browser configuration
        • Close Visual Studio.
        • In your project’s root folder, delete the .vs folder (this wipes cached settings including browser profiles).
        • Reopen Visual Studio and re-select the browser from the dropdown.
        • ToolsOptionsWeb Browser and Preview.
        • Under Web Browser, choose Edge (Chromium) — even for Chrome testing, it’s more reliable inside VS.
        • If you must test in Chrome, use the external browser option (right-click the file → “View in Browser” → Chrome).
        3️⃣ Check Internet Explorer mode security Since VS’s internal viewer still relies partly on old IE engine for non-Edge settings:
