Microsoft Edge - Mouse Right-click and Drop-down menus not working in
Chad Guidry 0 Reputation points
2025-08-19T20:31:47.0666667+00:00
I'm having the following issues with Edge
  • If I highlight text (either a URL in the address bar or text within a web site) then right click with my mouse, noting happens. I do not get the pop-up menu. Examples
    • to"copy/paste", have to use ctrl+c/v to copy.
    • to open a link in a new browser, I have to ctrl-click
  • If I am filling out a form that has a drop-down list, I do not see the options. I have to use the down/up arrows on my keyboard to scroll through.
  • When clicking on buttons such as the settings (the three dots next to the address bar), nothing happens
This is not a mouse issue. I do not have these issues with any other browser or any other applications.
I've attempted to download and run the Edge installer which did not help.
I do not have any extension applied (edge://extensions)
I have reset settings from edge://settings
Microsoft Edge | Other | Windows 11
  1. Jeronimo Fuerte 16,785 Reputation points Independent Advisor
    2025-08-19T21:18:14.3366667+00:00
    Hi! Sorry to hear that you have troubles with Edge browser, please try to perform this steps:
    1. Open Settings > Apps > Installed apps.
    2. Find the app > click the 3 dots > Advanced options.
    3. Try Terminate > Repair first.
    4. If still broken, click Reset (this wipes the app’s data).
    If this don't work, try Win+R then msedge.exe --disable-gpu
  2. Airbus A350 5,570 Reputation points Volunteer Moderator
    2025-08-25T19:46:16.1733333+00:00
    I'm encountering this issue too, and this started happening to me yesterday. In addition to this, I also have another Microsoft Edge profile, and all that I see on that account is a blank grey screen. Everything behind is accessible (I can go to websites), it's just that I'm unable to see it.
    For right now, I'd say to wait until Microsoft releases an update to Microsoft Edge to mitigate this issue.
    Hope this helps.
