How to connect Power BI with Azure Blob Storage with Service Principal authentication?
Santhoshsivan Murali 0 Reputation points
2025-08-21T09:14:19.92+00:00
I'm trying to connect Power BI with Azure Blob Storage to get data and for authentication I can only see four options which are Anonymous, Organizational Account, Account Key, SAS toke. In the documentation it is mentioned that Service principal authentication type is supported.
Which authenticating the Blob storage I can only see the above authentication.
User's image Please provide helpful insights for my query.
Azure Blob Storage
Azure Blob Storage
An Azure service that stores unstructured data in the cloud as blobs.
  1. Jeevan Shanigarapu 255 Reputation points Microsoft External Staff Moderator
    2025-08-21T12:50:50.0933333+00:00
    Hello @Santhoshsivan Murali,
    Welcome to Microsoft Q&A Platform. Thank you for reaching out & hope you are doing well.
    I understand that you are trying to connect Power BI to Azure Blob Storage to access data, and for authentication, you only see four options: Anonymous, Organizational Account, Account Key, and SAS token. It looks like you can't find the Service Principal authentication option.
    Since you are using the Power BI Desktop app, the service principal option is not available, and the Service Principal authentication is only supported in the cloud version (Power BI Service). This is by design.
    Power BI supports Service Principal authentication through Azure Active Directory (AAD) and Role-Based Access Control (RBAC), However, at present, there is no direct user interface in Power BI Desktop or Power BI Service for Service Principal authentication when connecting to Azure Blob Storage.
    In Power BI, selecting Organizational Account allows you to authenticate with an Azure AD service principal instead of a user account. To set this up, register an app in Azure Entra ID, assign the necessary Storage Blob Data Contributor or Reader role to the storage account or container, and use the service principal’s credentials (Client ID and Client Secret) for authentication.
    Service principal authentication is mainly available in the Power BI service for scheduled refreshes and dataset connections, which you can set up using Power BI data source settings or Azure Resource Manager connections. In Power BI Desktop, there isn't a specific "Service principal" option in the authentication menu. Instead, you use the Organizational Account option or configure the connection in the Power BI service after publishing.
    Reference links,
    Azure Blob Storage - Power Query | Microsoft Learn
    Authentication Method - service principal | Microsoft Learn
    Kindly let us know if the above helps or you need further assistance on this issue.
    Please "Accept the answer" if the information helped you. This will help us and others in the community as well.
  2. Sina Salam 24,096 Reputation points Volunteer Moderator
    2025-08-21T16:09:30.79+00:00
    Hello Santhoshsivan Murali,
    I understand that you would like to connect Power BI with Azure Blob Storage with Service Principal authentication.
    Irrespective of the document, if you can provide the link, that will be better. However,
    • You cannot pick “Service principal” for Azure Blob Storage in Power BI Desktop.
    • You can use Service principal in Power Query Online (Dataflows / Fabric), then consume that dataflow from Desktop (if needed, this might be a better option for your case).
    • Be aware of gateway and same-region firewall limitations and ensure RBAC is correctly set for the SP. - https://learn.microsoft.com/en-us/power-query/connectors/azure-blob-storage
    If you want, tell me your exact workspace setup (Service vs Fabric), storage firewall status, and whether a gateway is mandated. I’ll map your path 1:1 to the steps above.
