surface pro 11 type cover problem
준현 박 20 Reputation points
2025-08-24T04:23:07.0266667+00:00
I'm using a Surface Pro 11 ARM version. The Type Cover I've been using since the Surface Pro 9 doesn't have the Copilot button. When I connect the Type Cover to the device, the touchpad gets hot, not the screen. This doesn't happen all the time, but intermittently. This didn't happen at all when I used it with the Surface Pro 9. Is this a Surface Pro 11 issue or a Type Cover issue?
Surface | Surface Pro | Performance and maintenance
  1. ppavle 3,860 Reputation points Volunteer Moderator
    2025-08-24T18:44:45.0733333+00:00
    Please, check here compatibility for you type cover and Pro 11.
    https://support.microsoft.com/en-us/surface/learn-more-about-surface-pro-keyboards-and-type-covers-d6bba06f-1788-44b4-9e6b-743867343304
    It doesn't matter if you have copilot key or not. It's just a key.
