Those charger specifications seem odd as 20 volts x 3 amps = 60W, not 135W. Perhaps that is the per port limit. At any rate, if you are charging your device with a USB-C PD power source, the charging protocol there will negotiate the rate of charge between the charger and the device. If it is not USB-C PD, you should look elsewhere for a charging solution.
You are correct that Surface Pro 7, requires at least 60W for recommended power. More at https://support.microsoft.com/en-us/surface/usb-c-and-fast-charging-for-surface-d320ab19-e4ed-c36d-7458-7d7aec69d34a
Hope this helps,
Greg
