Hello KaNesha,
Welcome to Microsoft Q&A.
Based on your description, it sounds like the issue is caused by linked text boxes in Word. When text boxes are linked, Word treats them as a single flow of text. So deleting or editing content in one box can affect the others, even if they appear separate.
*How to check and break the link:
- Click inside the text box (not just the border).
- The Shape Format tab should appear at the top of Word.
- In the Text group, look for the option labeled Break Link, with a chain icon.
- If you see Create Link, the box is not linked.
- If you see Break Link, click it to unlink the box from others.
- Repeat this for any other text boxes that may be linked.
*If the issue continues, try copying all content into a new blank Word document. This method helps remove any hidden formatting or corruption that might be causing the issue.
I hope this helps resolve the issue. If you have any further questions, feel free to ask.
Warm regards,
